Gentlemen.,
I don't think there's any disagreement here., just a different means to an end.
To be clear., I
"LIKE" discs..!!
Power drum brakes have been around from the (approx.) 1950's up thru the 1980's & were "state of the art."
A properly maintained system worked perfectly, which makes the following incorrect;
"Putting a booster on front drums will cause problems: The drums will wear faster, need more frequent adjustment, and the booster will amplify any unbalance between the right and left wheels, especially in a panic stop."
Any neglected system will have issues, be it brakes (drum & disc) eng., trans., drivelines., cooling., etc.
I've seen many failed disc set-ups due to neglect, or parts failures. I've seen many a drum failures due to improper installation.
Many things "in play" here..! Knowledge, mech. experience, tools, Repair book, place to work, size of wallet., driving (bad) habits, etc.
For example; many folks don't realize when the spindles are pulled, the axles should be pulled, serviced, & new u-joints installed, or at least inspected. The spindle bearing as well., & the seals. (Assuming they've never been done) Otherwise one may have to start over again if a u-joint fails.
I bought my rig when I was in diapers...
/emoticons/
[email protected] 2x" width="20" height="20" /> :lol: :lol: and have run it hard for 20 yrs. SAME DRUMS & put on new shoes approx. 18 yrs. ago. I can't wait 'til the shoes wear down enough to replace again..!! Drums are still well with-in minimums.
Discs are GREAT & here to stay....however, a good drum set will get the job done quite well on these light trucks. Hydro or vac. assist is good as long as the drum sets are with-in specification.
