Bebop Man
I was browsing the local JY and found a York 210 A/C compressor in an old IH TravelAll. I thought the idea of some on-board air would be nice, so I grabbed it for a low price.
My first question was, where do I mount it? I wanted to keep my A/C, and all the fancy mounting doo-dads by BroncoAir are for 87+ with serpentine belts (losers). Then I remembered that I had disconnected my smog pump years ago, pulled off the belt and left it alone. I pulled off the smog pump and took some measurements, and figured out that it would fit with a few changes, mostly rerouting the heater hoses and a couple of wires.
I fabbed up an L-shaped bracket that lined up with the bolt holes on the compressor and used a short piece of round tube to anchor between the left-hand tabs. I still need to anchor the other side and make it adjustable so I can tighten up the belt.
The air lines where fairly easy to route. I'll need to get more pics from underneath. I put quick disconnects front and rear, on opposite corners. I mounted a 2 1/2 gallon air tank underneath the back seat, just behind the '****'.
Looking down on top of the setup. The steel braided line is the outlet from the compressor
, and will ***** into the check valve of the manifold once I get an elbow to make that bend a little easier.
I'll get some more pics from underneath tomorrow showing the mounting of the air tank and air lines.
