noise
89eddie89
charlotte nc
When i drive my bronco every once in a while i will hear a squeaking noise. and i am not sure what it is, because a few months ago i had the same noise keep happening.
so i replaced the driveshaft and the problem was solved. but now i can hear the noise again. does anyone know what it could possibly be?? and what i could do to fix it??
thanks
[-o<
bidibronco
Norfolk Va
Where is the noise coming from? Does it get louder as you accelerat or slow down or turn left/right?
89eddie89
charlotte nc
the noise is definately under the car.. somewhere most likely near the driveshaft
the noise stays the same. it doesnt matter whether i am giving it gas or coasting. it squeaks about every rotation. but i just dont know where it is coming from..
bidibronco
Norfolk Va
A little way to find out where the noise is coming from. Put the truck on some good sturdy jack stands under the rear axle. KEEP the vehicle OUT of 4wd and make sure the front hubs are unlocked. Start the truck and just inguage the tranny in any gear. Take a look under the truck and see exactally where the noise is comeing from and you'll get a better idea of what it is. Make sure the jackstands are stout enough for the weight and go about this the SAFEST way you can. That may give you a better idea of where the noise is and what is causeing it.
89eddie89
charlotte nc
That sounds like a good idea. I may try that
Ill get back to you and let you know what it could possibly be coming from..
89eddie89
charlotte nc
bill,
I would say it has been a good few months since the last time i lubed any of those parts up..
