Need all around input on this one
cjbronco
Jersey Shore
I have an 1982 bronco with 33's, 4" lift, 3.70'S and some engine work done to my 300. I need to replace my radius arms and i was thinking about going up to a 6" lift with extended radius arms, a sky shackle flip, ladder bars(mostly for looks, but do spin some in the wetsness) ans superlift's super runner steering setup. Ans possibly going from single to quad shock up front and MAYBE the rear(again prob wont but its a nice look factor) Well, whatcha think? :-B
texan79&96
the july off road adventures has a good article about the ttb suspension geometry you should research it some and see if you think you will like it or not going up 6". thats a lot of money to be spent on looks. if you have the cash for all that might as well spend it on a straight axle swap if you are wanting a 6" lift and extended arms. it will stay in alignment much better and your tires will last longer because of it.
CJB, if you plan to go up to a 6" lift, I would highly recommend the extended radius arms. IT will allow for more wheel travel and help out with the front axle caster. IF you want to add an extra shock per front wheel, look for replacement shock towers. I agree that a dual-shock set-up in the rear axle would be sweet, but haven't really seen a good design anywhere. Good luck going 'higher'!!!
eholt80
