Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Yep that is where the jack and lug wrench mount and the crank handle for the jack clips along the front atop the radiator support. If you have tires that are 32" or bigger the little factory jack is useless without propping it up on something. And it ain't very safe!
Both my lug wrench and bottle jack are on the passenger side in those bracket. However I took the bottle jack out once and i don't believe I ever put it back correctly, because it just doesn't seem to fit to well.
got those as well and the tire iron and jack are on the right and jack handle is across the rad I use them to hold a long neck funnel (for trans ) and the breaker bar that wont fit in my tool box inside
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
