Loose ground?
hambone69
i have a 95 bronco 302 and having problems starting and shuts off while running. I've changed/inspected most of the starting system and was wondering if anybody has a diagram or could tell me where the grounds are located?
oktogo
york sc
the block ground should be on the passenger side of the engine, thats all i know of.
Battery ground goes from the Battery (-) to the passenger side front of block, from there to frame. The other engine ground is from the rear driver side of the intake to The fire wall, (braided strap or a number wire).
Seabronc got it correcto mongo again!
Here are some pics & diagrams, diff years & engine type in some, but all are same as your 95. I've been collectng em for awhile and figured now is da time to post em up and add/change em as I get my eyes coordinated w/my brain. I may have mixed some up such as in instr panel showing "upper ground" confused w/"lower ground"
Engine Block pic in a 94 5.8; "...The black battery wire goes from the front bolt of the engine mount (on the block) to this tab & up to the battery post, where a smaller black wire goes to the core support, providing a continuous ground path between the engine, frame, battery, & body..."
Source: by CodysBigBlueBronco (how much $???) at SuperMotors.net
Frame & Battery pic in a 93; "...With the wheelwell gone, it's easy to inspect the frame ground, just inboard of the spring tower on top of the frame rail. The battery ground cable is stripped ~3/4" and a tab is soldered on so it can be bolted to the frame..."
Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
Intake Manifold to Block Strap Location pic in a 96 5.0
Source: by boss (bossind, Steve) at SuperMotors.net
it is between 2nd & 3rd plugs on passenger side
All remaining from the 96 Ford Workshop Manual
Fender Apron (passenger side)
G101 front of engine compartment, front of fender apron (D1) - RH = Passenger side mine has 2 small black wires between starter relay & headlight; this is #5 in the diagram
Location pic by Steve83
http://www.supermotors.net/getfile/829927/thumbnail/enginebay93rhf.jpg
5 — Body Grounds (Part of 12A581)
19 14301 Chassis Ground
Fender Apron, Left
10 N806972-S36MG ***** to Ground Wire Assembly this;
G100 & G104 (tied together in diagram)
G100 @ LH front of engine compartment, on upper radiator support
G104 @ Rear of LH fender apron near hood hinge and 4WABS Test Connector (RED)
G100 Serves Component:
LH Oxygen Sensor
Fuel Pump Module
Inertia Fuel Shutoff
Misfire Sensor
Misfire Sensor Shield
Output Shaft Speed (OSS) Sensor
Powertrain Control Module (PCM), 5.0L
G101 Serves RH Oxygen Sensor
G104 Serves Component:
Component
4WABS Control Module
4WABS Data Link Connector
4WABS Relay #1
Instrument Cluster
Powertrain Control Module (PCM), 5.8L
Programmable Speedometer/Odometer Module (PSOM)
Trailer Relay Box
Engine Starter Subsystem and Battery, 5.0L, 5.8L and 7.5L Engines
12 14301 To Engine Ground
18 12A581 Body Grounds
23 N802777-S36 Bolt for 14301 Frame Ground (same as in Steve83's pic)
G103 (battery to engine) Lower RH front of engine
Component
4WABS Pump Motor
Battery
Data Link Connector (DLC)
Mass Air Flow (MAF) Sensor
Right Front Park/Turn Lamp
Right Front Side Marker Lamp
Right Headlamp
Cowl, Dash Panel and Door Wiring
7 — To Ground (Part of 14301) This is G201 Behind bottom of LH cowl panel (driver's side kick panel)
Component
Compass/Outside Temperature Module
Day/Night Mirror
Inside Cargo Lamp
Left Power Lumbar Compressor Motor
Outside Cargo/High Mount Stop Lamps
Right Power Lumbar Compressor Motor
Seat Belt Switch
Door Lock Actuator (PDL & Probably Power Window Motor)
Instrument Panel Wiring Installation, F-150, F-250, F-350 and Bronco (Gasoline Engines)
36 14463 To Ground (this is G201); it is on pass side
RH Inner Cowl Wiring pass side
8 — To Ground; this is G200 Behind bottom of RH cowl panel
Component
Air Bag Diagnostic Monitor
Electronic Shift Control Module
Instrument Cluster
Remote/Keyless Entry Module
Speed Control Servo/Amplifier Assembly
Trailer Tow Wiring (Rear Frame), Bronco
5 — Trailer Tow Ground Wire (Part of 14405); This is G401 @ LH rear corner of cargo area, near rear lamp assembly
From my Notes:
G103 (battery to engine) Lower RH front of engine Component
4WABS Pump Motor
Battery
Right Headlamp
NOT SHOWN:
G400 Rear Window Defroster @ LH rear corner of cargo area, near rear lamp assembly
Fryman22
