firelt90bronco
Ask me about my job
Why would you break the rear window and then have to climb all the way through to open the door??????? The vent window is cheaper.
Hopefully no one that lives close by you reads this board.View attachment 4000i have an 84 ford bronco and i can kinda hit the door right between the door handle and the window and my lock usually comes up enough to open the door so if it happens again just try it ............ it worked for me
hhahhahahahaha thats amazing ) ) /emoticons/[email protected] 2x" width="20" height="20" />) )i have an 84 ford bronco and i can kinda hit the door right between the door handle and the window and my lock usually comes up enough to open the door so if it happens again just try it ............ it worked for me
Find a wire coathanger. Stretch it out. shove the hook between the weatherstripping and glass right above the handle. Fish around with the hook until you catch the wire that opens the hande and than pull straight up. That should open it.Like the title says. . . i sorta locked the keys in the car while finishing up working on the truck. (my only set of keys)
Does anyone know how to open the doors without having to break a window?
I would have done that but the truck had most of the electrical ripped out. . . .no power locks /emoticons/[email protected] 2x" width="20" height="20" /> So. . . . I had no choice but to do this :
Waiting 20 min and less than 40 to get it opened is cheaper than that piece of glass.....
I've owned fords all my life, I've never called AAA or any other service. Are you sure your not confusing your evil thoughts with a Chev you've owned in the past. Why are you bashing Fords on a Ford specific site? Are you an enemy spy?man all these ford guys and nobody mentioned AAA? not only free towing, but free locksmith service as well.
owning one ford will make your membership pay for itself.
