knocking when it starts
thornbirdguy
Jamesville, NC
i changed the oil in the truck the other day(yes, i call my bronco a truck).i have no clue what oil the previous owner used, but i have been using pennzoil 10w-40. well, for the first time i went with a k&n filter. now whenever i start it, it knocks for a few seconds and then goes normal, like when you first start it after an oil change. does the k&n have a bypass valve for cold oil startups? it doesn't just do it first thing in the morning, but every time i start it. the pressure has also dropped quite a bit(still have a factory gauge...only goes up to O or R in normal, used to go up to M ). 1 dry start when you first change the oil is bad enough, but now it dry starts every time. what can i do here? would switching to 20w-50 help any?
Shadow_D
Schenectady, NY
Ok first I doubt it is the filter, I've used K&N for a few years now and never had a problem.
Next, how many miles and what motor also check your oil level.
I'm thinking if the oil level is where it should be then you might have a pump that is on it's way out.
If you have a 351W with over 100K miles the mains might be going as well. Do you hear it knocking when you are at idle for 2 or more minutes after the motor comes up to temp? You should see the oil pressure drop as well.
T
thornbirdguy
Jamesville, NC
Ok first I doubt it is the filter, I've used K&N for a few years now and never had a problem.Next, how many miles and what motor also check your oil level.
135k miles, "rebuilt" at 125K, 5.0L. oil is full. it only knocks when i start it, and only for a second or two.
T
thornbirdguy
Jamesville, NC
Ok that isn't too bad then. Shouldn't be doing it all the time but once the oil has cooled it might.
well, a guy at work told me to use a dodge truck filter, which is shorter, and the problem should go away. he said it will take a shorter time for the filter to fill up and that the shorter filter will raise the pressure a little. anyone ever done this or know someone that has?
