Ignition Actuator Installation
Matticus
I have a broken ignition actuator, I have removed the old one but I am having problems installing the new one. It has the long shaft on it attached to the semi circle part and it will not fit into the sleeve down the column due to another metal part on the column. I can't see anyway of seperating the pieces, is there a secret? I know this is a pretty typical problem. The help is much appreciated.
Matt
BroncoJoe19
New Jersey
Matt
Matt,
Not having done it myself, I don't know what the problem is, however here is a pictorial of how one user installed a new one. Maybe he came accross your same issue and solved it.
http://broncozone.com/forums/index.php?s=&...ost&p=57274
good luck
joe
M
Matticus
Joe, Thanks for the link, I think that should take care of it. --- Matt
BroncoJoe19
New Jersey
Matt,
Glad to help, and welcome to broncozone.
IF that link does not help, let us know. I am certain that a few members have taken that apart.
So again, if you are stuck give us a shout.
joe
JLasvegas
that was an awesome link, now I know how to fix my shift indicator
thanks
