How would I add 3" of lift to my current 6" lift?
shipwreck
Northern Ca
I have a 79 Bronco with a 6" suspension lift on it and was wondering how I could add more lift to it because I have a set of 39.5" Iroks I want to use and want to make sure I have plenty of clearance. I am looking to raise it another 3-4"
Would I just add a leaf in the rear and new coils up front? I am new to this. Funny thing is that I am still in Iraq and haven't even physically touched my truck :) /emoticons/[email protected] 2x" width="20" height="20" /> My wife bought it for me since while I have been in Iraq. The guy she bought it from said it has about a 6" lift on it.
here is a pic of the truck and some of what I know about it
-1979 FORD BRONCO RANGER XLT
-33 3/4 IN" TIRES
-SUSPENSION LIFT ABOUT 6 IN'
-DUAL FRONT AND REAR SHOCKS
-400
Ziggy
Riverside, Ca
Are you sure you want to go that high? 9" of lift will bring your CG way up and cause some problems. With 3 more inches of lift, you will propably have to re-alighn the drive shaft angles by rotating the axles. Not really ******* the rear, but the front axle is major work. You will also have to new driveshafts made or your old ones lengthend. And since you're increasing tire size you should change your gears to spin the bigger meat. You could run 35's with out a problem on a 6" lift, or consider triming your fender wells and installing some after market fender flairs to clean up your trim job.
Hope your enjoying Iraq, where are you stationed? I spent 7 months at Al Asad (El A**hole), temps went from 130* in the summer to 28* in the winter.
79bigbronco
Calgary, Alberta, Canada
If you do a shackle flip you will gain 4-5" in the rear, fab some angled coil spacers for the bottom of the frt. springs, use 7* C bushings. a frt. driveshaft out of an 89 with a 1356 t/ case, and get a longer d/shaft made for the rear. I run this setup, and have 10" in the rear,8" frt. and could run 39's with ease, oh and you need 12" wide rims to get the proper backspacing . I do find you need some form of traction control though, I use a modified upper link for mine.
shipwreck
shipwreck
Northern Ca
Thanks for the info! That helps out a lot.
I am at LSA Anaconda 50 miles north of Baghdad. I am an EOD tech (Bomb Squad) the guy that disarms all the damn roadside IED's and whatever else that is made, dropped, shot, or unexploded. I leave here June 12th or so..
captgivens
Arizona
22695[/snapback]
Hey troop, change of pace. Just wanted to say Thank You from all of us back here in the real world. Keep your head down bro, and let us know when ya get back. And WOW your wife should be up for sainthood, she's a keeper!!! Prayin for Yall.
Ziggy
Riverside, Ca
We flew in and out of Anaconda numerous times. Keep your head down and good luck on your return.
shipwreck
shipwreck
Northern Ca
Thanks guys, I really appreciate your comments. I am proud to serve and proud of my bros that serve. Wouldn't change my decision of joining the military for anything. I have been in for 13 years and 7 more to go! My wife is awesome and she is what keeps me going! I am a lucky man :) /emoticons/[email protected] 2x" width="20" height="20" />
fred tyler
