High Pinion 3rd Member, who sells them?
Mach1460
I have a 5.5 lift on my 69, The rear drive shaft seems to me to be at too much of an angle. Who sells the high pinion 3rd member? Also what way is there to measure driveshaft angles so that I know if I have to much of an angle?
STLKIKN
Calgary Alberta
I have 5.5" JBG springs in my 69 as well...
Steel 8* shims will correct your driveline angle problems.
You need to measure three places to figure out your true angles.
The angle of the shaft, and at both the yokes (as vertical as they will be)
The difference is where your concern lies.
With the double cardan joint at the top of the shaft, you should have no problems, anything under four degrees at the diff is liveable, but you want to be closer to 1/2*, No less then the half though, or your u-joint will not self lubricate properly.
M
Mach1460
Are you talking shims that go between the lift blocks and the axel? Sorry, im still a little blurry on how to actually measure the angles, what type of measureing devise works the best?
STLKIKN
Calgary Alberta
Hmmmm, sorry, I assumed you had 5.5" springs....
Before rushing out to buy shims, buy or rent an angle finder like the one yardape linked to.
We can figure out what you need to do after we know your angles.
Broncoholics
Broncoholics
Washington State
Take the driveline off the axle end only and see how much further it can drop before it binds when rotating.
Most times you want the axle pinion yoke to point just below the t-case yoke so the u-joint keeps lubed ike stated. I've seen some go above (rotate further) but you better have a good traction bar. Works well for driveline angles but can create a bad bind at the u-joint under torque without a bar.
You can lower your t-case to help lessen the angle.
Talk to Tom Woods @ http://www.4xshaft.com/index.html
I run their drivelines and they flex a bit further and have a warranty.
S_bolt19
Colorado
you can also relocate your spring perches and rotate the entire axle tube. BUT, Currie, Randy's Ring & Pinion & maybe Complete Offroad may have the HP rear end, might even have it as nodular.
eholt80
