hesitating
Johnny Wayne
Oceanside, Ca
I have a 90 with 5.8. Around 1700 to 2100 rpm I feel a hesitation or shuttering. Above and below that rpm its fine.
I have to try and figure out if there are some codes but I was wondering if anyone had experienced that.
Thanks.
madmax
quakertown pa
I have a 90 with 5.8. Around 1700 to 2100 rpm I feel a hesitation or shuttering. Above and below that rpm its fine.I have to try and figure out if there are some codes but I was wondering if anyone had experienced that.
Thanks.
might be time for plugs and wires, cap, rotor, and coil, a relitivley in expensive job.
or you're fuel injectors could be dieing, mine started to cause it to stumble when given just a little gas from an idle. changed them out to bosch quad port high performance injectors, and the truck runs awesome. even if i had only gotten regular gp sorensen's it'd still be better than stock, they are simply better at making good fuel injectors now.
also check the air filter, might have sucked a couple leafs against it, did that once and wondered where the **** my power went.
Johnny Wayne
Johnny Wayne
Oceanside, Ca
I actually just changed cap and rotor and it still is doing it.
Airfilter is fine.
I bought new plugs for it but I have not been able to change them out.
Thanks
Gryph
