Help! Tire carrier has cracked right rear corner
houstonheights77
I am new to this forum and am very excited about my newly purchased 1977 uncut early Ford Bronco. My first Bronco! And I know I should have asked this question BEFORE I actually purchased the truck...but I couldn't help myself. Here's my issue: the tire carrier has caused a small but very visible crack in the right rear corner of the truck. Has anyone else had or seen this problem? Is it easy to fix? How? I appreciate any thoughts, comments, help...etc.! Thanks in advance.
PS---Sorry for the double posting...I initially posted this on Tech Support forum, but re-posted here because it looks like this forum may get more action.
Bronc76
I posted one in tech support
Modernization did that...
That rack was meant to hold a small tire...now days we haul huge tire/wheels & gas cans hanging on the rack.
The rear quarter panel gets locked to the tail-gate & limits the frame/body flex--equals-- crack in sheetmetal.
Mine was cracked prob. when I bought it..! It's still cracked...but no further.
My rack has two vertical bolts that serve as a hinges. (yrs. ago) I put 3 home-made teflon 1/8" washers on ea. hinge point & left the lock-nuts a bit loose. this allows for quiet movement as the rig flexes.
Your rack prob. has the large hinge/knuckle so that won't work for you.
There are aft. mkt. racks out there that rest only on the bumper.
If the crack bothers you..., body-shop it.., or you can repl. that whole corner.
BTW.., there's a large backing plate behind the sheetmetal...or should be.
Best to fill-in your sig. & info pages to receive more accurate help.
HTH
