Headers
HarrisBrocno95
texas
i am new to the ford brocno zone. i have a 95 302 with a 5.0
im about to put new long tube ****** headers on my 1995 ford brocno. I wasnt sure if it make is worth doing a true dual exhast or just getting a y pipe with one muffler and two cats.
KansasBronco
Kansas
good luck putting in an x tube or anything like that. i had to go from the headers, cruve to go outside of the frame, into glass packs, and then out before the tire. good luck!
Yes, it's difficult to run true dual exhaust on the Bronco due to the transfer case and front driveshaft interferance on the driver's side. Most often, it's easiest to run shorty headers into the stock y-pipe, then split the exhaust after the cats.
rubberdust
Henderson NV
The shorty headers like Edelbrock offers into a Y pipe then a single 3 inch collector for the cat & muffler will give you decent flow & save the clearance headaches
stusainte
01085 Ma.
Justshootme I have a 95 302 5.0 and picked up some shortys but the factory Ypipe does not match up you mentioned they will match up Am I not seeing something while laying underneath my Bronc or is there a certian way the headers and y pipe fit together
Make sure the headers are for your year-model Bronco, not just the engine size. Might also post what brand in case anyone else has had a problem.
stusainte
01085 Ma.
There Ford Racing Shorty headers for 92 to 96 ford 302/5.0 I installed the drivers side header and tryed to match up the factory Y pipe but it seeemed to be about two inch to narrow thought maybe I was seeing things so I thought I would check here
Coastersfwb
