michibronc
Just wondering if there's any special prep work to be done to paint the hard top on a 96. I seem to have sort of a pebbled finish which I believe is from the factory. It's a very fine texture.
I don't know all the specifics, but when my boss's 96 eddie bauer was hit and the redid the top the body guy we know real well said there was a special paint that has to be used. I'm not sure what, he didnt go into the specifics.Just wondering if there's any special prep work to be done to paint the hard top on a 96. I seem to have sort of a pebbled finish which I believe is from the factory. It's a very fine texture.
i was told to use steel wool just to get teh texture of the old paint offJust wondering if there's any special prep work to be done to paint the hard top on a 96. I seem to have sort of a pebbled finish which I believe is from the factory. It's a very fine texture.
If you're talking about gelcoat be careful with that stuff. I've used it in the past to "paint" my diving helmets and it's real thick stuff. It's hard as can be but I'd be concerned about losing the texture. Might just be that you could apply the gelcoat in such a way as to retain or even lay down a new texture though. It would be worth speaking to someone at a marina or a shop that does boats.then fiberglass boat paint i heard works the best
