yo RON,
This is by Ford and brought out in da open by a group of Fold fixers;
Lubricant And Maintenance Materials Specifications & Capacity Charts for 96 Bronco, F-150, F-250, F-350 & F-Super Duty
Ford Axles (Conventional and Limited-Slip) b c Premium Rear Axle Lubricant
Ford Part Number XY-90-QL
Ford Specification ESP-M2C154-A
b For Ford design rear axles: add 4 oz. of Friction Modifier C8AZ-19B546-A (EST-M2C118-A) for complete refill of 8.8-inch ring gear
limited slip rear axles.
c Synthetic High Performance Rear Axle Lubricant F1TZ-19580-B (WSL-M2C192-A) may be substituted but only after axle assembly is completely drained.
Fluid Change & RockCrusher Cover Installation in a 96 w/parts & tool list
Source: by boss (bossind, Steve)
Also check vent rubber tube; some get dislodged from fitting on driver's side of axle tube
Ford advises; "plugged axle vent will cause excessive seal lip wear due to internal pressure buildup. When a leak occurs, check the vent which is located near the top of the differential housing. Make sure the vent hose is not kinked. Remove the vent hose from the vent ****** and make sure the hose is clear of dirt or other foreign materials. While hose is removed, pass a length of mechanics' wire or small diameter Allen wrench in and out of the vent ****** to clean it of any dirt or foreign materials. Install vent hose."
Some off-roaders or owners who live in flood prone areas extend the vent line
such as;
Vent Line Extension Installation w/filters in a 96; Dana 44 & 8.8"
Source: by vegasbronco1 at
http://www.supermotors.net/registry/9065/33043
http://www.supermotors.net/registry/media/306267
Vent Line Extension Installation w/filters in a 95; Dana 44, 1356 transfer case & 8.8"
Source: by Pepper (J A F O, Big Pig) at
http://www.supermotors.net/registry/37/14315
Vent Line Extension in a 96 w/filters; "...Top of E4OD with extended breather line. Had to grind it a little for the tube to fit. The filters i put on the breather lines. One has the two differentials and the other has the transmission/transfer case.."
Source: by 96broncoman at
http://www.supermotors.net/registry/7622/55540
GL!
