Gauges temp and oil
swede bronco
Stockholm
In my 89 Bronco the temp gauge has taken time out and the oil gauge is next to time out, works in the lower part of the scale next to the L. I have seen a lot of questions and answers about the Ford gauges in this forum and I have learnt they are just crap but still I want them to work. I have installed VDO gauges for oil and temp but I don
redneckpunk
Hopkins michigan
You can disassemble the dash from the inside (behind the stearing wheel) ounce you get to the guages just pull them out they come out 2 by 2 the problem is there expensive around 150 to 175 per set. usually that will fix it It did mine but mine came from a donor truck. but they come in different combos depending on your truck.
Coastersfwb
