B-Co Kid
- Joined
- Oct 14, 2010
- Messages
- 235
- Reaction score
- 8
1987 351w, holley 570 (about to be replaced
with edelbrock 600) c6 trans, mechanical fuel pump. I've had a fuel pressure problem for some time, and I can't seem to figure it out. My fuel pressure gauge reads abnormally high around 9-10 psi. I was told It could be my liquid filled fuel gauge. Replaced it with a non-liquid filled gauge, and still reads high. I thought it could be the mechanical fuel pump, but it works fine, I think, when I press the throttle, fuel squirts in the bowls of the carb. Its not a performance fuel pump. What causes high fuel pressure with engines using a mechanical fuel pump? And on a side note, anyone considering using Holley's clear sight plugs to adjust the float level, DON'T!! I did, and the friggin plug broke off leaving it threaded in the sight hole, with no way to unthread it. Anyway, high fuel pressure. What causes it and how do I rectify it?
