Hello everyone,
I recently bought a 1979 Ford Bronco (trailer special). It is completely original with absolutely no mods. I am rebuilding the truck and starting with the engine. It has a 6.6l 400m engine. Listed below is how I plan to rebuild the engine. Does anyone have any thoughts or advice about it?
* New 400m shortblock (stock)
* Stock oil pump, oil pan and waterpump
* Edelbrock 61629 - Edelbrock Performer RPM Cylinder Heads 60cc Chamber,190cc Intake
* COMP Cams CL32-242-4 - COMP Cams Xtreme Energy Cam and Lifter Kits Duration 262/270,Lift .513/.520
* Weiand 8010 - Weiand Action+Plus Intake Manifold
* Holley Carburetor, Model 4160, 750 cfm, Square Bore, Manual Choke, 4-Barrel, Vacuum, Dual Inlet
* COMP Cams Magnum Steel Roller Tip Rocker Arms (Rocker Arms, Stud Mount, Roller Tip, Steel, 1.72)
* Hedman Hedders 89210 - Hedman Street Hedders
* MSD Ignition 8350 - MSD Pro-Billet Ready-To-Run Distributor Magnetic Pickup, Vacuum Advance
That is it for new add-on engine parts. I do not know how much horsepower and torque it will produce when completed, but I have to guess that it will be over 400 hp and over 400 torque. Any comments are welcome.
