Ozark Hauler
Hey folks , Steve here from Missouri .
Found BZ' after some searching . I've got a 94' F/Size EB Bronco that's been "Road Hard" but is still a great Truck . It's basically stock ,with a mild shift kit,6 Rancho 9000's , New Smitty Bilt seats , and a Sony Disc system for the tunes .Front end bushings are new ,the old ones were gone .
Bar a bad engine and a wiring harness destroyed by Saber Tooth Tree Rats' (ie:Squirrel) it's still a real nice truck. It's got almost 164k , the 351 has finally gone "Tango Uniform"(some of you Military folks might understand that one) I left it in our back yard for a week and a Squirrel got up under the hood and ate the harness (Injectors&Intake Air Sensor plugs) 2 of the plastic Vacuum Lines and last but not least the coil wire so it could make a nice nest about the size of a basket ball . > I had just ordered my new engine and gone outside to pull it around to the shop when I discovered the damage those little Tree Rats' did . Had to cancel the engine.Called Ford and they told me that the harness was obsolete . Went out trying to find another truck and no luck .They were all Rot Boxes and Bondo Queens that had up to 267K miles for $5500.00 and up .
So I called another Ford Dealership they told me to call this Electrical Repair Shop in Springfield . They got me the #'s for the Plug Repair Kits ,took them back to Ford and finally crossed them to good #'s . So after looking at dozens of overpriced pieces of ****** I got the kits ordered and tomorrow I'll reorder the engine .
I just could justify scrapping or selling the Bronco because it's so clean cosmetically . I had put several requests out to parts hotlines and found only one 95' with a harness . (won't work-I've got the one year only harness in my truck) It was $100.00 for 2 Injector Plugs and the Air Temp plug .
This Bronco lays my old Blazer to waste in every way ,ride,mileage and the Mule Like towing . But like a typical older Ford it's been getting Wiring Gremlins before the the Tree Rats' got a hold of it . It's had a new Tranny ,and I'm on the 4th battery in 3.5 years of owning it (we live down a Cattle Track Road) . I've busted 3 batteries since we moved to Missouri.
I got the hood off last night and will start to break the engine loose tonight .
I've never done one of these Computerized beasts (mostly restore Classic Cars) .So this looks like it'll be a chore . Is there a way to leave the A/C lines connected and still get the engine out ? Getting to the bell housing bolts looks like a Fiasco as well .
Does anyone have any tips for me on pulling this engine ?
Thanks ,
Steve
These pics are coming into our property thru the second wet weather creek on our road
Thanks ,
Steve
