First get a replacement ****** you should be able to get one from a parts supply that handles Holley carbs.
For an automatic transmission
Assuming no one has messed with the cold idle ***** on the passenger side, (hard to get at), or the idle mixture. You can run it in until the engine will idle while in park, usually around 1100 RPM, (engine at normal operating temperature), (turn ***** clock wise to increase idle RPM). Next you will have to adjust it till the engine idles around 500 - 600 RPM in drive, (Chock the wheels, put on the emergency brake and have someone in the truck with their foot solidly on the brakes, if you have life insurance make sure it is not the beneficiary
/emoticons/
[email protected] 2x" width="20" height="20" /> ). Once you get it to idle without stalling in drive, you will need to road test and probably play have with it a little so it doesn't stall when stopping.
For a stick shift adjusting it to around 450 - 500 when not in gear should do.
