engine trouble
hockeyfreak55
georgia
i have a 94 bronco with a 5L 302 engine automatic. when i first start her up and put her in drive its works ok till it goes to shift to 2nd. then it just revs and i can't get it back in gear till i turn it off and let it sit for a few minutes. i don't know whats wrong.
help!
help!
Is the Transmission Control Indicator Lamp (TCIL) Flashing ? (it;\'s da OD ON'Off Switch?LED at end of tranny shifter stalk.
If so, Get it scanned for DTCs or diy; BroncoJoe has a DIY self test here
no, the TCLI is not flashing but it wouldn't hurt to check for DTCs. anthing else it could be?
Could be TPS sensor; but don't replce it... yet..check for Codes first.
have to go now, sorry, will be back next week; others will help you along soon; just ask what you need to find out.
If you do have a code(s) post it here; and look in my site under electrical... here is the URL http://www.broncolinks.com/index.php?index=118
GL!
