Engine swap 351m for L99 (ls3) and more. CRAZINESS!
Pinner46
Wyoming
I have an 81 xlt that I am going to do a little work to (or quite a bit) starting with a 2012 Camaro SS 6.2L L99 engine with 6L80E 6-Speed automatic. Then take the interior of a 2018 f150 platinum to upgrade the interior. Any thoughts??
Yo Pinner46,
You will bet the first Bronco Big owner to perform this swap that I know of, good fortune!
Let's start by researching the Camaro's 6.2 engine and the trans specs as to size, electrical requirements and controls, etc and then figure out an approach.
1981 Bronco Brochure - Gary's Garagemahal (the Bullnose bible) by Gary
1980-1986 Bronco/F Series Fasteners by Gary
1980-1986 Bronco/F Series Carburetors, Chokes & EFI by Gary
1980-1986 Bronco/F Series Specifications by Gary @ Axle Ratios - Gary's Garagemahal (the Bullnose bible)
Differences in 1980-1986 Bronco/F Series by Gary
➡ 1981 Bronco/F Series Electrical & Vacuum Troubleshooting Manual (EVTM), partial via Gary @ 1981 EVTM - Gary's Garagemahal (the Bullnose bible)
EEC III Testing, if not removed or disabled by a previous owner or shop via Wayback Machine by Tommy
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via BroncMom
Partial Chilton Manual for 1978, 1979, 1980, 1981 Bronco. Scanned by broncocity.com @ Bronco City
paul rondelli
Atlanta
So Dr Frankenstein .... you plan on pulling the heart out of your Bronco ...and put in a Chevy heart in it's place?
Would you then call it a BroBlazer ... or a bastard?
just kidding ...... good luck .. and start a build thread
Doesn't the 1981 have the swiss cheese frame ... where they just cut holes in the frame? You are sure going to be putting in a lot more weight on that front end
Frame - Gary's Garagemahal (the Bullnose bible)
Sounds like a fun project but I second the "I think that frame is not the best choice" opinion.
better check it.
What transfer case? or is this 2 wheel drive?
P
Pinner46
Wyoming
Its will be a bastard haha. My thoughts are to make it how the new Broncos should have been (now with a chevy engine just needs more power) I was thinking putting a raptor front end on it to give it a sporty look. And after reading some posts it looks like I need to beef up the frame. It is a 4x4 and I'm not sure on the transfer case.
@paul rondelli
@Tiha
@miesk5
