Engine revs up in the park
Wingback806
Allen
Hello guys I have a 95 Ford bronco XLT and when I put it in park every now and then it revs up to about 1300 RPM and stays like that for a while. What you guys think the problem is
Yo W,
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Some basics;
Do KOEO test First
KOEO
KOER
THIS WILL PROBABLY HELP DIAGNOSE A SENSOR OR WIRING or vacuum leak......
and also: Throttle sticking or linkage binding."
Usually a bad or a good IAC would result in a low, erratic idle..my 96 had a good IAC, but the throttle body holes were mostly clogged... have been using a TOP TIER Gas (Shell) but now I am certain the station owners are subbing non-Shell gas in their tanks)
However, I have heard of a bad IAC causing a high idle.
Read this by Mike:
Ford vehicles with an Idle Air Control Motor (called IAC) that have idle problems and sometimes noise concerns can be diagnosed in the following manner. For high idle problems, try unplugging the IAC motor. If the idle drops, its usually due to an input signal to the computer which results in the computer raising the idle speed. If this is the case, look at all of the computer inputs to make sure everything is up to par. If the engine RPM does not drop when the IAC motor is disconnected, then either the IAC motor is not functioning properly, or, there is a vacuum leak in the engine. Stop the
engine, remove the IAC motor and block off the passages. Restart the engine to see if there is any change in engine
RPM. An idle speed higher than base idle specs indicates a vacuum leak. If the engine RPM is at base idle specs, then
the IAC motor is bad. Resistance specs are 7-13 ohms. A good resistance reading does not necessarily mean that the
IAC motor is good. Occasionally, an IAC motor will become weak, and will actually bypass too much air, causing a
high idle condition even though everything else is operating properly.
Read more at
http://web.archive.org/web/20030411092204/www.carquest.com/techbulletins/engine_controls/tt3q00.CQ.pdf
CD66
