It will slide right in there. It is actually the same height as the carb is, so you don't need a body lift. You need to get everything that is associted with the EFI system. The harness, EEC, any and all sensors, intake manifold, plenum, fuel rails, and I would even get those heads. Look for any 5.0 system really, 'stang, cougar, grand marquis...any will bolt directly onto your block. The more desireable is the mass air system, but the speed density system is great as well, that is what I have been running for about 5 years. The mass air is easy to identify because of the fuel injectors, they are orange where the SD unit is either grey or black. Hope that helps you some.
