EEC IV Diagnostic Routines;
1994 PCED OBDI-A
SECTION 2A: Diagnostic Routines​
Diagnostic Routines Symptom Flow Charts — Chart 5
Symptom​
OASIS Number​
Unique Idle Concerns
—Slow Return to Idle​
617400​
1994 PCED OBDI-A
Diagnostic Routines Symptom Flow Charts — Chart 6
Symptom​
OASIS Number​
—Rolling Idle​
618400​
Runs Rough
608000​
—Idle​
608400​
1994 PCED OBDI-A
Diagnostic Routines Symptom Flow Charts — Chart 7
Symptom​
OASIS Number​
—Fast Idle​
619400​
Additional Driveability Concerns
—Diesels/Runs On​
621000​
Note: If the vehicle runs normally after the ignition key is turned off, check for faulty ignition switch, IGN RUN circuit short to power, etc. Refer to Service Manual.
1994 PCED OBDI-A
Diagnostic Routines Symptom Flow Charts — Chart 8
Symptom​
OASIS Number​
—Low Idle​
Stalls/Quits
607000​
—Deceleration​
607700​
1994 PCED OBDI-A
Diagnostic Routines Symptom Flow Charts — Chart 9
Symptom​
OASIS Number​
Stalls/Quits
607000​
—Acceleration​
607500​
—Cruise​
607600​
Runs Rough
608000​
—Acceleration​
608500​
—Cruise​
608600​
Misses
609000​
—Acceleration​
609500​
—Cruise​
609600​
Buck/****
610000​
—Acceleration​
610500​
—Cruise​
610600​
—Deceleration​
610700​
Hesitation/Stumble
611000​
—Acceleration​
611500​
1994 PCED OBDI-A
Diagnostic Routines Symptom Flow Charts — Chart 11
Symptom​
OASIS Number​
Surge
612000​
—Acceleration​
612500​
—Cruise​
612600​
1994 PCED OBDI-A
Diagnostic Routines Symptom Flow Charts — Chart 12
Symptom​
OASIS Number​
Backfires
613000​
—Idle​
613400​
—Acceleration​
613500​
—Deceleration​
613600​
1994 PCED OBDI-A
Diagnostic Routines Symptom Flow Charts — Chart 13
Symptom​
OASIS Number​
Lack/Loss of Power
614000​
—Acceleration​
614500​
—Cruise​
614600​
Note: Verify symptom is reported under normal driving conditions without engine/vehicle excessive load conditions.
1994 PCED OBDI-A
Diagnostic Routines Symptom Flow Charts — Chart 14
Symptom​
OASIS Number​
Spark Knock
615000​
—Acceleration​
615500​
—Cruise​
615600​
1994 PCED OBDI-A
Diagnostic Routines Index
Gasoline Engines
Driveability​
OASIS Number​
Chart Number​
Starting​
No Crank​
601300​
Concerns​
Hard Start/Long Crank/Erratic Start/Erratic Crank​
602300​
Stall After Start​
No Start/Normal Crank​
603300​
Unique​
617400​
Idle​
Rolling Idle​
618400​
6
Concerns​
Fast Idle​
619400​
Low/Slow Idle​
Driveability — Performance While Driving Concerns
Stalls/Quits​
Idle​
607400​
(607000)​
Acceleration​
607500​
9
Cruise​
607600​
9
Deceleration​
607700​
Runs Rough​
Idle​
608400​
6
(608000)​
Acceleration​
608500​
9
Cruise​
608600​
9
Misses​
Idle​
609500​
6
(609000)​
Acceleration​
609500​
9
Cruise​
609600​
9
Buck/****​
Acceleration​
610500​
9
(610000)​
Cruise​
610600​
9
Deceleration​
610700​
9
Hesitation/Stumble
(611000)​
Acceleration​
611500​
9
Surge​
Acceleration​
612500​
(612000)​
Cruise​
612600​
Backfires​
Idle​
613400​
(613000)​
Acceleration​
613500​
Deceleration​
613600​
Lack/Loss of Power​
Acceleration​
614500​
13
(614000)​
Cruise​
614600​
13
Spark Knock​
Acceleration​
615500​
14
(615000)​
Cruise​
615600​
14
Diesels/
Runs On​
621000​
Poor Fuel
Economy​
622000​
15
Emissions
Compliance​
623000​
16
Malfunction Indicator Light (MIL) Concern
DCL Message Received (Continental Only)​
698298
698198​
17
Electrical
H
Warning Indicators​
—MIL​
206000​
17
—DCL (Continental Only)​
698298​
—TCIL, 4x4 Low, SIL​
698198​
Climate Control​
Lack of cooling (AC) (AC not functioning)​
208200​
29
(208000)​
AC always ON/AC compressor runs continuously​
30
A/C does not cut off under WOT conditions.
(Applications with WAC circuitry)​
31
Instrumentation
—Tachometer Inoperative​
204000
204128
204228​
19
Lighting Systems-Exterior Lighting​
201000​
—Stoplamps always on​
201228​
—Stoplamps always off​
33
Driveline
Manual Transmission Concern​
—Shift Indicator Lamp​
505698​
17
Automatic Transmission Shift Concerns​
—A/T upshift concern​
501000​
—A/T downshift concern​
502000​
18
—Engagement concern​
503000​
Engine
Oil System Concerns​
401000​
—High Oil Consumption​
401100​
20
—Leaks​
401800​
Cooling​
Overheating​
402300​
21
System​
Runs Cold​
22
Concerns​
Electric cooling fan never runs​
21
(402000)​
Electric cooling fan always runs​
22
Exhaust System Concerns​
Visible Smoke​
403400​
23
(403000)​
Odor (Sulphur/"rotten egg" smell)​
403596​
34
Fuel System Concerns
(404000)​
404201​
24
—Odor, Engine Compartment​
Engine Noise (Under Hood)​
497000​
25
Governor will not Limit rpm (7.0L MFI)​
27
Noise/Vibration
Vibration Concerns​
703000​
26
No Symptoms Present
EEC-IV Quick Test​
32
DIESEL ENGINES
All driveability symptoms​
28
1994 PCED OBDI-A
Symptom​
OASIS Number​
Lack/Loss of Power
614000​
—Acceleration​
614500​
—Cruise​
614600​
sf66
