Early 66 questions...
STLKIKN
Calgary Alberta
I've got a friend with no internet access that has just brought an (early?) 66 Bronco to Calgary from Arkansas...
It has some strange things going on with it, that I have never seen.
Has anyone seen a stock hood with no air duct slats in the corners?
The air inlets for both the heater and the fresh air are stamped/ welded steel that run from the rad support to the fire wall along the top of the wheel wells, anyone seen this before?
Broncoholics
Broncoholics
Washington State
I think the first year for the air inlets was 67. 66 didn't have that option yet. Or something along those lines...
STLKIKN
STLKIKN
Calgary Alberta
Here are some pics... any ideas???
the pics with just the holes are from the front of the rad support...
I worked in HVAC & that looks to me like someone with A/C tin-bending experience decided there was "a better way."
Much easier & cheaper to just repl. the rubber seal between hood & cowl.
I have a real early '66 & my bro has a '67 ......
He prob. had some water comming in & changed things instead of fixing. Looks like an OK job but he had to move stock wiring, etc., & the ducting takes a lot of room. :rolleyes:
STLKIKN
STLKIKN
Calgary Alberta
I've been in and under and around the dash and cowl of the truck, anything with a visible part number is Ford. Even the fresh air vent...
The hood is untouched... as is the pass kick panel.
This all looks like original tooling, that is why I am asking if anyone has seen it before.
figjeti
