e.f.i engine?
bluesman17
Spam Terminator
South Bend, Indiana
351w are all the same just the intakes change for efi or carbs. check auto stores, autozone advance auto (pep boys [-X )
BLADE262US
Michigan
There not all the same the later 351W,s 95 / 96 are roller motors so the distributor gear is different from riding against a steel cam . And somewhere in the late 80,s they went to a one piece rear main seal instead of the 2 rubber half circles . Just FYI :D /emoticons/[email protected] 2x" width="20" height="20" />
anyone know where i can get a new 351w e.f.i engine?
27507[/snapback]
If you want one that is mostly complete, get a "short" or "long block" from one of the auto parts places like Auto Zone, NAPA, etc. You can also do a Google search for "Ford crate engines". That should get you plenty of hits.
S
sreaminbronco
Dallas
on a long block whats left to be put on? And if I was going to get a long block from a place like autozone and i put all my accesories and etc. to complete the engine how much horsepower and torque do you think it could crank out?
bluesman17
Spam Terminator
South Bend, Indiana
If its just the longblock with no mods or anything itll be stockhorsepower, but if your current engine is tired that alone will make it feel way more powerful.
27535[/snapback]
If you want to bump it up very far from stock, start with a block, and get your self a book on building a performance engine. Then you will also need to invest in a beefier drive train to keep from snapping drive shafts, axles, etc.
eholt80
