driver side window
luvmybronc
Can anyone tell me how easy or hard it would be to replace my driver side window it got busted out the other day and its too cold to drive round with no window....
bidibronco
Norfolk Va
I'm assuming it's the driverside door window. It's not to hard to replace, but you do have to dissasemble most of the door. The easiest way I have found is to take all the weather stripping off around the top and sides of the window and make sure your window roller thingy is all the way down. After you get the window in, you should be able to slide the weather stripping down the sides. Just be carefull not to bend the weather stripping to much. GOOD LUCK
~bidi~ @-)
L
luvmybronc
well went to a salvage yard pulled a window out of an 83 bronco and well im guessing its a little to big but its in just not the wing window wont close its all out of wack so it must be a tad to big but id rather have a little window that wont close than no big window.. is there anywhere i can find a cross refrence book so i know what parts will always inter change with my truck?????
bluesman17
Spam Terminator
South Bend, Indiana
80-96 all parts are interchangeable except hoods, frenders, grills, and headlights (unless you change the core support out) :)>-
L
luvmybronc
ok so any ideas cause its up now but its real tight and when its up all the way the wing window wont close it bends that support bar out at the top and things just dont mate up!
31802[/snapback]
What year truck do you have? Add that information to your signature, it makes it easier to read your mind :) /emoticons/[email protected] 2x" width="20" height="20" /> .
Goof luck,
L
luvmybronc
well hi again seabronc i have talked to you many times only before i moved and lost my p.c stuff you would have known me as ladybronco. my truck is a full size 88 with a 302 you might remember all the help you gave me with my gas tank a while back. nice to see you again and thanks for all your help!
wrachet
Kansas City Area
If you roll the window down...does it wobble back and forth or front to side if you shake it? To me, it doesn't sound like things are lined up right and not a case of the window being to big. Of course, I could be wrong!
Colleen
L
luvmybronc
no it doesnt move at all just fits a little to tight i called up some people and they said theres 2 different numbers for the 83 and 88 so im pretty sure its a tad to big but right now it fits tight and at least when i drive theres no big hole freezing me out...****
eholt80
