Does anyone have a 1986 EVTM
I'm looking for a schematic for the Stereo radio that was shipped with the 1986 Bronco. If you do, would you either photograph that page or scan it in and post it here.
Thanks,
Thanks,
Fred, I know Chris B (Blue, bronco boy) has posted a few 86 Bronco EVTM pages on his telus site; suggest you contact him @ FSB and ask; he is a-ok as you probably know.
Electrical and Vacuum Troubleshooting Manual (EVTM) Partial, Bronco for 86; Speed Control, A/C, Heater Source: by Ford via Chris B (Blue, bronco boy) at telus.net
I did look thru all the pages, but no radio diagrams
BroncoJoe19
Here is a wiring diagram for a 1990 Bronco radio.
I am pretty sure that Blade262US has an 89 EVTM, I'm kinda surprised that no one has an '86 that is willing to scan on for you.
BTW.. Ground 100 is the left hand side of the radiator support.
With ignition switch ON fuse 11 give power to the radio
Fuse 8 is always on to give power to maintain memory for preset stations
Panel dimming is controlled but the instrument panel dimming switch. A variable voltage is applied throught the 19 (LB/R) wire to control the brightness of the panel lamps.
The display's brightness is controlled bu th emainlight switch. When the park lamps are turned on, battery voltage is applied to the radio through the 484 (O/BK) wire. Teh display will dim. When the park lamps are turned off, voltage is no longer reduced by the dimmer resistor and teh display will brighten.
For further DX one is referred to teh shop manual.
