Dash Lights
Mike G
TN
Can anybody tell me if the rear window (tailgate) switch and the push button 4x4 switch on the dash have lights in them. Nether of mine light up when the headlights are on. I kind of think there should be because my rear window defrost switch lights up.
Also is there some kind of light in the gear shifter that tells me the OD is on or off? And if yes how do you change it or make it work?
Thanks in advance
love_my_bronco
Spokane
Thanks in advance
for the rear window no there is no light but the four whell drive yea there should be a light for it. and there is no light for OD for what i know.
Mike G
Mike G
TN
I have the dash lights that indicate when I'm in 4H or 4L. Just thought there should be a light in the switch itself to see what your poking.
yo!
from Owner's Guide:
"The Transmission Control Indicator Light (TCIL), which is located on the gearshift lever, may flash steadily if a malfunction has been detected. If the TCIL is
flashing, contact your Ford dealer as soon aspossible. If this condition persists, damage to the transmission could occur. NOTE: The word
Mike G
Mike G
TN
Thanks for that miesk5. I guess if all else fails read the book. I did notice the little "Off" light on the gear shift. Does the end of the gear shift just pop off?
Mike G
Mike G
TN
Found it at LMC truck. Below is the information if anybody else needs one.
P/N 45-0792 Item (13) OVERDRIVE SHIFT BUTTON &CAP 92-96 (1) 7.95
