muddrivermike
Ok what Im trying to find out is A 79 f250 dana 44 FRONT axle and a 79 f350 dana 60 FRONT axle hub bearings,As inner and outer....Are they the same bearings or are the 60s bigger?The reason is I found a front dana 60 for sale from a 79 f350.I want to put the 60 in my bronco only because Im under the assumption that the 60 has bigger hub bearings than my f250 44 in the front of my truck now.Im tired of bearings coming loose over time in the front due to the 40 inch ground hawgs I have,So I figure if a 60 has bigger bearings It can handle the tires better.Auto zone and advance auto shows the same part numbers for both axles,,BUT broncograveyard shows otherwise.I dont what to put out a good amount of money on this axle if the 60 doesnt have bigger hub bearings..And solid input would help,,Thanks Mike
