critters
Nasty, At least it doesn't look like they were chewing on anything. Amazing where they will build a nest.
We have had a squirrel issue here for years.
Worst was loss of vacuum to brake booster.
chrlsful
S. Amherst, MA 01002-1827
temp visitors, Unless mice & this was parked in ur garage. This is cuz they don't travel very far. Would hafta free the house or garage. They will come back. My solution, drive it daily. aahahahaa.
If stored - folks do all sorta stuff. Up on spec blocks w/reverse collars (cones pointing down). All thru holes either caulked or grometed. Stuff moth balls around in nooks/cranies of the vehicle, and more...
chrlsful
amazingly enuff we've had them go speciffically for the insulation on wires and hada do full / costly / labor intensive / re-wires. I am all ways amazed at just what they do. NO nutrition in plastic wire inslution. What gives? Just mean?
Other cases U get as per the above pic. Just some danger to ur health. No smoking or food till hands washed (just like covid, disease spread w/hand to face - eyes ears noise'n mouth R entry points). Stay safe, some pretty bad stuff contracted this way~
johnnyreb
West Virginia
Last year when I raised the hood on my Caddy. Their must have been 15 or 20 little mice running in all direction. Cat,s and snakes are good to control them,but I guess the cats around hear and snakes must be sleeping.JUST ONE BITE is a good way to get rid of them.
S
sgtdjl
enfield ct
So after lifting the engine to install the new oil pump pickup and pan / sending heads out to get busted bolts extracted electric cooling fan installed 2.5 inch exhaust from cat back runs better than before
That is great news.
Always good feeling when a project turns out like that.
johnnyreb
West Virginia
don't know it was hidden under the upper intake on the right side
I know what a intake is on the older model motor,but are you saying the later models has more the 1 (one) intake? My Dodge Ram is a 2001 and it only has one. What year of bronco do you have and year of motor?
johnnyreb
West Virginia
Could someone post a picture of a UPPER MANIFOLD ? I thought their was only 1 intake manifold . Sits on top of the motor and the exhaust manifold(s) would be lower on each side of the motor.
Yo Johnny,
Ford designed later year Big Broncos with and Upper intake manifold and a lower one;
ItemPart NumberDescription
1390773-S36Stud
29J444Intake Manifold Support
3383745Nut
4388469Stud
5390704-S2Stud (49 States Only)
614A163Wiring Harness Retainer (49 States Only)
79F483EGR External Pressure Valve (49 States Only)
89D476EGR Valve Gasket (49 States, over 3864 kg
[8500 Lbs.] GVW Only)
99424Intake Manifold (Upper)
109D475EGR Valve (California and 49 States Under 3864 kg
[8500 lbs.] GVW)
119A474Intake Manifold Vacuum Outlet Fitting and Cap
129A474Intake Manifold Vacuum Outlet Fitting and Cap (49 States)
139A474Intake Manifold Vacuum Outlet Fitting and Cap (California)
149J459EGR Vacuum Regulator Solenoid
159S448Secondary Air Injection Vacuum Regulator Solenoid (49 States, Under 3864 kg [8500 Lbs.] GVW)
169S448Secondary Air Injection Vacuum Regulator Solenoid (49 States, over 3864 kg [8500 Lbs.] GVW)
1712A310Coil
1812N004Ignition Coil Mounting Bracket
1918801Radio Ignition Interference Capacitor
2040904-S36***** and Washer Assembly
219F792Fuel Injection Supply Manifold
2217A084Engine Lifting Eye
2356359***** and Washer Assembly
249G271Evaporative Emission Return Tube
259E527Fuel Injector Nozzle Tip
266766Oil Filler Cap
27387549Bolt
286582Valve Cover (LH)
29390453Bolt
306375Flywheel
31388058Bolt
327007Engine Rear Plate
339A424Manifold Seal (Rear)
346584Valve Cover Gasket
356051Head Gasket
366049Cylinder Head
379430Exhaust Manifold (LH)
389F485EGR Valve Tube to Manifold Connector (49 States, over 3864 kg [8500 Lbs.] GVW)
396750Oil Level Dipstick
406754Oil Level Indicator Tube
4112A406Spark Plug Heat Shield
42388469Stud
4312405Spark Plug
4417A084Engine Lifting Eye
45388469Stud
4645358Nut
476714Oil Filter
486L626Oil Cooler Mounting Bolt Insert
496A642Oil Cooler
506890Oil Filter Mounting Insert
516A008Cylinder Head to Block Dowel
526675Oil Pan
536734Oil Pan Drain Plug Gasket
546730Oil Pan Drain Plug
55391496Bolt
56391495Bolt
576710Oil Pan Gasket
586020Engine Front Cover Gasket
59388192-SBushing
606019Engine Front Cover
618507Water Pump Housing Gasket
626700Crankshaft Front Seal
636K471Oil Cooler Adapter
648509Water Pump Pulley
658501Water Pump
66388895-S2Bolt
678555Water Bypass Tube
68383522-S102Clamp
69388522-S8Stud
706C351Timing Pointer
716C365Misfire Sensor
726010Cylinder Block
739A425Manifold Seal (Front)
749439Intake Manifold Gasket
75390948-S36Stud
7687617-S100Plug (California and 49 States, Under 3864 kg
[8500 Lbs.] GVW)
7712A697Intake Air Temperature Sensor (49 States, over 3864 kg [8500 Lb] GVW)
7810884Water Temperature Indicator Sender Unit
799424Intake Manifold (Lower)
806N789Water Outlet Connector Gasket
818575Water Thermostat
829N347Fitting
838592Water Hose Connection
8456535Bolt
859F485EGR Valve Tube to Manifold Connector (49 States, over 3864 kg [8500 Lbs.] GVW)
869430Exhaust Manifold (RH)
879F485EGR Valve Tube to Manifold Connector
8812270Hold-Down Clamp
8942955Bolt
909D447Vacuum Tube to Intake Manifold Clip (California and 49 States, Under 3864 kg [8500 Lbs.] GVW)
91379930-S2Nut
929J433EGR Transducer
93N807714Clamp
94381222Elbow
959D477EGR Tube (49 States, Over 3864 kg [8500 Lbs.] GVW)
9612127Distributor
9712A217Distributor Base Adapter
9812106Distributor Cap
999471Intake Manifold Shield
1006768Crankcase Vent Filter (RH)
1016582Valve Cover (RH)
1026A664Oil Separator Hose
103389772-SClamp
1046A666Positive Crankcase Ventilation Valve
106391136-S8Bolt (49 States)
1079E926Throttle Body
1089E936Throttle Body Gasket
1099F715Idle Air Control Valve
1109F670Idle Air Control Gasket
111390589-S2Stud (California)
112390358-S8Bolt
11318472Heater Water Hose
1149B989Throttle Position Sensor
115N803851-S52*****
Yo, Part 2
Note that I am tired of the image restrictions!
UPPER INTAKE MANIFOLD
156703Bolt
49A474Connector
59424Intake Manifold (Upper)
69H486Intake Manifold Upper Gasket
79471Intake Manifold Shield
8390358Bolt (5 Req'd)
9390249*****
ATighten to 17-24 Nm
Lower Intake Manifold:
1Nut (Part of 9K461)
29F792Fuel Injection Supply Manifold
3391445Stud
4Locating Pin (4 Places)
(Part of 9K461)
59424Intake Manifold (Lower)
6391443Bolt
7Clip (Part of 9K461)
ATighten to 11-13 Nm
(8-10 Lb-Ft)
BTighten to 31-34 Nm
(23-25 Lb-Ft)
Lower Intake Manifold Sensors, Injectors, etc.
1ECT Sensor Location
(Part of 9424)
29F593Fuel Injector
39C968Fuel Pressure Regulator
49D280Fuel Injection Supply Manifold
59D930Fuel Charging Wiring
6Fuel Return Tube
(Part of 9F792 Assembly)
7IAT Sensor Location
(5.8L, 49 States Only)
(Part of 9424)
8Water Temperature Sender Location (Part of 9424)
9Pressure Relief Valve
(Part of 9F792)
johnnyreb
West Virginia
Yo, Part 2
156703Bolt
49A474Connector
9390249*****
3391445Stud
(Part of 9K461)
6391443Bolt
(8-10 Lb-Ft)
(23-25 Lb-Ft)
(Part of 9424)
29F593Fuel Injector
6Fuel Return Tube
(Part of 9424)
(Part of 9F792)
Thanks
