Big Country
Hello all,
I was driving down IH-10 the other day and my truck just died. no sputtering, nothing. Towed it home, lifted the hood. and the first place i checked was spark. I took a plug out put it in the wire and had someone crank it. Someone told me i should see a spark. I didn't buy that but tried it anyway. No spark. Does this mean i don't have spark or is there an better way. i don't have a meter but also heard that if you take one of the wires off of the plug and put it next to metal on the truck it would arc. Is this true? I really don't feel like being shocked cuz it happened one time when it was really cold on another bronco and it split my finger open. Crazy!! Anyway i also checked to see if the throttle linkage being pumped was getting gas to the carb. i didn't see any. The pump was jsut changed 6 months ago, supposedly. I doubt my mechanic everyday something else goes wrong witht he truck. It was leaking during the summer and they wre supposed to replace it. i think they just tightened it. Anywho, someone else told me that teh fuel pump won't pump fuel unless the truck is on. They said there is enought fuel in the carb during cold start to fire the engine up. Again i didn't believe it but figured i would ask here. I need to find out if i need to replace ignition module or coil or both or if i need to replace the fuel pump or if by some crazy coincidence they all went out at the same time. Thanks!!
