check engine light
nine milly
Horsham pa
ok heres the problem runs fine i dont feel a miss.. when im driving when i get to about 1200-1500 rpm the check engine light will flash as soon as the trans shifts it goes off
nelbur
When the check engine light comes on, a code should be remembered by the CPU. Yours is newer than mine so someone else will have to tell you how to check codes on your truck.
here is a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
Look Codes up in my broncolinks.com site using the new Search function.
KOEO
KOER
Are all Emission Components in-place? And all vacuum lines in-place and no leaks; ck under dash too for HVAC hoses and vac motors for blend door, etc.
Forgot to mention soon in your profile, include your year, engine, trans, Xfer case & locking hub type (auto or manual) and any major mods such as body or suspension lift, etc. or in any question post. You'll get more accurate replies
btw; how did the Frame issue go?
