tiller83
83 bronco,351w-c6-np208,feels like the engine power is not getting to the wheels on road, mostly when the system is cold or not registering at the dash yet.the c6 was rebuilt some years ago but I soon swapped to a t18 and the c6 sat up,but the 208 has been kicking the entire time.the 351 was replaced at the same time the c6 was rebuilt,it's a mexican block.I put the c6 in with a 302 and an np205 in an 86 bronco I got with no drive train,it worked fine,even with c72 (35 inch) tires and 3.55 gears.the c6 is now back inbetween the 351 and the np208.I was told by an older autozoner that there is a bushing in the 208 that fails and causes restriction,power loss.I still have the 205 but I'd have to change and modify my crossmember,among other things,to use it.So I need to know if I should rebuild the 208,go with the 205,or am I running blind in a mine field.?
