Foul Al
Hey folks, I was driving the other day and noticed that my tranny sounds like its chattering when its about to shift. it typically does this when i'm getting on it. I have checked the fluid and its full and not burnt and the mounts and lines are secure. I thought about my Bronco build for a while and the only thing I came up with is the tranny I swapped into it was a 2wd tranny that I had the center shaft and the deeper pan swapped to it for 4wd. under "tender" driving conditions it shifts perfectly fine.
My build is as follows...
76' "j" code 460 freshly rebuilt with edelbrock intake and 650 cfm carb with l&l headers
2wd c-6 tranny freshly rebuilt with shift kit and the center shaft and deep pan swapped for 4wd application, additional trans cooler in the system
np 205 transfer
9" rear with 3:50 gears
all new u joints
35'' tires on 15'' wheels
my theory is that the 2wd trans is laboring with the smaller rear or its not sturdy enough for a 4wd application.
I'm not verry familiar with the internals of a tranny so any help or suggestions are always helpful.
np 205 transfer
all new u joints
