chaindrive
the plastic inside door handle (driver's side) on my '96 bronco broke off the other day.
usually this is no big deal to fix.
HOWEVER, the last time whoever changed out the last broken one, stripped the threads on the ***** that holds the handle on.
i found another ***** at the hardware store (local ford dealer can't find one on the computer) and wonder i can use it to run new threads, or should i take it to a shop to have them run a tap through the female threads.
i was told that the assembly that receives the ***** may need to be replaced if the job is hosed up.
how expensive would this be?
BTW: found metal door handles on e-bay so hopefully this won't happen again.
thanks.
thanks.
