battery decisions
yusuebronko2_86
San Antonio TX
hey guys:
I'm fed up with my battery always leaving a puddle of acid in the box I have it in, as well as the termilals losing contact due to the fact that the posts have been shrunk due to years of service. Should I:
A: just buy a new post-type battery
-or-
B: buy an eye type battery (the kind that ***** into the front)
also, my stock battery tray had been devoured by acid about two years ago, does anyone know where I can find one in the area of 80 miles west of San Antonio? :huh:
BLADE262US
Michigan
I have been running optima batteries for a long time and have never had any problems with them . They are a sealed gej cell so you dont have to worry about them leaking can mount them upside down if you want . I have been getting them off ebay the yellow top deep cycle dual post top and side for $155 shipped to me . :D /emoticons/[email protected] 2x" width="20" height="20" />
brianlr7773
hey guys:
            -or-
22576[/snapback]
I would also highly recomend a sealed optima gel battery.. You can find a red top optima at almost every auto store for around 100 - 120 .
A little more than a conventional battery, but you can shoot it and it will still work, or have your cooling fan brake and a blade go through it (REALLY HAPPENED) out in the middle of no where, still worked and drove it back home and even for a few more days before i was able to change it. Best part is, it cranks out around 950cca and has very very fast recharge rate. I never even worry about my battery anymore, my optima redtop has been in my truck for more than 5 years.
Batterys have come along way, using acid and water is just to dang messy for our classic cars anymore, I don't want acid eating my truck.
:) /emoticons/[email protected] 2x" width="20" height="20" />
First, check your volts at the batt. Overcharging will cause your simptoms. (boiling over, steaming, etc.)
So will a faulty batt. or over filling.
Not sure what over-charging will do to an Optima
I've run the cheapie batt's for 15 yrs. & one faulty batt. did spill over.
Oh, Autozone has "good" cheap batt. trays & all the lock-downs
Also, .. hold your post-clamps closed with plyers & run a hacksaw blade thru the slot a couple times...clean-um up & good to go..!
wrachet
Kansas City Area
I agree with BullyBob on checking for overcharging! It'll definitely cause some batteries to blow caps and do all sorts of messy things.
You should be able to find a battery box at Advance Auto, Autozone, O'Reilly's...heck they may even have them at Wal-Mart.
As for a new battery...well you'll need one <grin> but I'm not sure what kind. I prefer posts over the ***** in type.
Colleen
Y
yusuebronko2_86
San Antonio TX
the thing is, as far as overcharging goes, I have an alternator out of an 89 that is almost new, so that isn't the problem, so why is it still leaking and such?
wrachet
Kansas City Area
22747[/snapback]
The voltage regulator could be bad. On some models, the voltage regulator is inside the alternator.
Could have a faulty ground...
You can only get so much out of a battery...replace the battery and then go from there if you are still having the problem.
Colleen
Y
yusuebronko2_86
San Antonio TX
wooooooohooooooooooooo!!!!!!!!!!!!!!!1
my first new battery in my entire life (F.Y.I, i've been getting hand-me-down autozone batteries)
my problems are gone, excluding the fact that the old battery ate up the stock tray and half of the tray under-frame, but not to worry, i'm a welder, that kinda thing is a joke! lol!
wrachet
Kansas City Area
wooooooohooooooooooooo!!!!!!!!!!!!!!!1my first new battery in my entire life (F.Y.I, i've been getting hand-me-down autozone batteries)
23410[/snapback]
It's amazing what a new battery can do for you!!! LOL....now to build a battery box.
Colleen
Sufferedformula
