Axle converzion?????????????
BroncoKID34
:angry: [-( What does it take to changea twin I beam or split front axle to a solid front axel on my 89 Bronco???????? I asked this same question a week ago give me some answer..
Try a search for "SAS " or "solid axle swap". Installing a straight axle in place of the stock TTB takes some fabrication. Also, search over at FSB (fullsizebronco.com), they have a separate forum just for SAS. You can also check the link to "MiesK5 HomePage" in the Tech Articles section here at BZ. That will answer 99.99% of your Bronco questions.
Good luck!!!
ocalabronco
ocala, Fl
is there a particular reason why you want to do this swap? it takes a moderate amount of know-how and general working understanding of 4x4 suspension to properly set up the geometric angles required in this swap. its not hard to do, but it requires patience and a fair bit of skill
BroncoKID34
33927[/snapback]
I'm not sure what your trying to say, but the reason I want to do this swap is b/c I want to put a pretty big lift on...and in the end I would like this to be a rock crawler.so yeah..Im sure I'll have no problem w/the geometric angles. Im used to workin' on race cars. I've raced everything from,stock v8 class to dirt late models I am know in IMCA racing series. Im pretty smart when it comes to the geometrics. and I have been doing alot of research on 4x4 suspension. My friend Chris and Jason are also there to help me.but chris has a super duty f350 and jason has a 2000 Z71 but I figured I would asked you guyz (b/c yall are Bronco Owners. so please just help me out as much as possible dont question me just help!!!! MIKE b-( thats my friend chris' truck
SoFlaSwamper
33971[/snapback]
search is your friend, i'm new here too and i know that question has been asked a million times.
basically just got a dana 60 or dana 44 straight axle and custom fab your front so it works. simple as that
countryboy
central ny
what me did for a friend of mine who wanted to do that is we took a 78 bronco frame and axles and but his 90 bronco body onto it ( may have to check mounting locations on your bronco) :)>-
ocalabronco
ocala, Fl
33971[/snapback]
i asked the question so that you would ask yourself if you REALLY needed to do the swap. Bronco's in their stock form are plenty capable, and even with the TTB, there's not alot of places you cant go with 35's and lockers front and rear. yea its nice to have 1 ton gear under your truck, but you're looking at 1500 to 3K, maybe more, for a quality 1 ton swap. if the money isnt an issue, the go for it. just trying to possibly open your eyes to another possibility. I'm glad you can build race cars and what not. but 4x4's and race cars are two totally different worlds. Keep doing as much research as you can and learn as much as possible about our suspension options
SoFlaSwamper
33993[/snapback]
i beg to differ...when I had 36" swampers, I would get stuck EVERYWHERE man and I think that I'm a really good driver when it comes to off-roading. Now, with 44s, i crawl everywhere.
35's are good for rockcrawling and what not but for serious mud, you're out matched unless you're just runnin trails
bidibronco
Norfolk Va
33971[/snapback]
34031[/snapback]
sounds contradicting wouldn't ya say?
ocalabronco
ocala, Fl
34031[/snapback]
well that is kinda what he wants to do........rock crawl. and when i had 35" thornbirds, even open/open there wasnt much i couldnt go through with the right momentum and steering.
eholt80
