automatic transmission
Neldog
My question is I hear a loud clunk when shifting into reverse and was wondering if it is the u joint? The noise comes from the rear but only when shifting into reverse. Sometimes it shifts fine into reverse. I see there is play in u joint when rotating drive shaft back and forth and here the noise when driving. Shifts fine into other gears. My engine is a 351m and a c-6 automatic
Cmprice
mine does that about 75% of the time also...my grandpa told me its normal in this year and not to worry about it
swampthing
try to tighten the yoke up they loosen over time..and if you have play in your u-joint i'd change it...it may take care of your problem
N
Neldog
How do you tighten up the yoke ? and how do you take the slip joint off of the rear driveline mine won't come off and the repair book I have doesn't mention it?
Sandoval_broncosauria
