Auto trans
wileycoyote
Jackson Hole Wyo
I am looking for some advice, Have a stock 79 bronco 351M with a C6 trans. Is it possible to get a 4 speed auto to bolt up? will it increase mpg? or is the gearing in the differentials a factor as well? i am running 33x12.50. Any insight would be highly appreciated.
crowebait
did you mean the E4od or and AOD, the E4od will bolt up but you have to have a computer to run it, the Aod will not bolt up as it has the 302/351W bolt pattern, i think some companies make an adpter for it but not sure.
if you go with the E4od you can get a stand alone computer to shift the tranny from computshift or baumman.
Sandoval_broncosauria
