94 Bronco Cruise Control
Lou
My cruise control stopped working. I checked the fuses and they are OK. What is the next step to take? Has this happened to anyone else?
Lou
check the cables goin gto the TB see if they are still attached I had a F-350 that they every once and a while would come loose. the cruise controler is located to the right of the master cylinder on the fender wall .
Raven,
I checked the connector on the cruise control, but it's in there tight. When you say TB, do you mean the connector?
Lou
Lou
TB= throtle body.
Does the speedo still work in your bronco? If not your CC won't work either. check the VSS sencor on the rearend.
Lou
TB= throtle body.
Speedo works fine
squatch23
Back
