84 B2 swap 4wd manual into 87 b2 2wd AT
terry martin
I have 87 B2, 2.9 v6, 2wd and AT 3.73. also have donor veh complete, 84 B2 2.8 v6 5 speed manual. want to swap 4wd from 84 into 87, also swap manual and get rid of A4ld. will this work with no problems? thanks so much. both veh have same gear ration, 3.73
Clem
It will work, but.
Check to make sure the spring buckets are the same for the front end.
The part I am not sure about, is what parts you will need to change when you put the clutch in. All manuals from 86 on, have hydraulic clutches, if the 84 doesn't, you should get one, if it does, swap it with the transmission.
Before I upgraded my 86 B2, it had an assembly on the top of the clutch pedal arm that I believe was to disconnect the ignition.
You will also need to add a couple wires for the manual shift/transfer case, (put the bulb in the dash to show 4x4 hi-lo). I think the neutral wire from the A4LD can be adapted to, or spliced in for the manual, and the reverse switch for the back up lights can be done the same way.
As you do the swap, you will find things you will need to change and wiring that will need to be deleted or spliced.
Good luck, take your time, it will work.
Ray
T
terry martin
It will work, but.Check to make sure the spring buckets are the same for the front end.
Ray
T
terry martin
thanks so much for reply. got any ideas on where to find hyd clutch assembly. the 84 doesnt have one, I am sure. thx
Clem
Any manual transmission from an RBV, (Ranger based vehicle, Ranger, Bronco II, Explorer) up to 1995 and possibly newer.
According to the Chilton's manual, your 84 does have a hydraulic clutch. On the engine side of the firewall, drivers side, you should see a light colored container with a ***** on lid and a hose out the bottom. Follow the hose down the firewall, it should connect to a part that is attached to the firewall on the outside. Now go inside and look under the dash at upper part of the clutch pedal arm, it has a rod attached to it, that is the rod that pushes the piston in the hydraulic cylinder you saw the bottom of in the engine compartment. While you are looking under the dash you may as well figure out how you are going to remove the clutch pedal assembly, you are going to need it, hint, the metal panel under the steering column is removable, some were screwed on, others had plastic twist screws.
Do you have a Chilton's or Haynes manual? If you do not, you should get one, you are going to need it before you are done with is swap. A manual will give you the specifics that will be very hard to explain here.
Ray
T
terry martin
Any manual transmission from an RBV, (Ranger based vehicle, Ranger, Bronco II, Explorer) up to 1995 and possibly newer. According to the Chilton's manual, your 84 does have a hydraulic clutch. On the engine side of the firewall, drivers side, you should see a light colored container with a ***** on lid and a hose out the bottom. Follow the hose down the firewall, it should connect to a part that is attached to the firewall on the outside. Now go inside and look under the dash at upper part of the clutch pedal arm, it has a rod attached to it, that is the rod that pushes the piston in the hydraulic cylinder you saw the bottom of in the engine compartment. While you are looking under the dash you may as well figure out how you are going to remove the clutch pedal assembly, you are going to need it, hint, the metal panel under the steering column is removable, some were screwed on, others had plastic twist screws.
Ray
thanks so very much. I take your advice. I bought a ford shop manual and it is being shipped to me now. again, thank you.
Clem
I screwed up, only a 2.8, 2.9 or 4.0 transmission will work, the inline 4's and the 3.0 have a different bolt pattern.
I wanted to install a M50D-R1 from a 3.0, it has a lower first gear than the one for the 4.0, but the bolt pattern is quite different.
Ray
Similar threads
T
Replies
Views
802
Top stories on BroncoZone.com
T
T
Replies
Views
923
T
T
Replies
Views
2K
T
T
Replies
Views
914
T
fred tyler
