Powerstroker 86
- Joined
- Mar 13, 2010
- Messages
- 2
- Reaction score
- 0
I have been reading a lot on this forum and there is a lot of good information and people. I've been a member of ford truck enthusiast for many years now but i posted my new project there and haven't gotten any help or advice.
So here's the paper plan (we all know how this goes btw once i start though) taking a 79 Bronco and removing engine and transmission. it has a 351 with a c6 auto in it. all of which are running and working properly if anyone is interested in purchasing them. I'm looking at installing a 99-02 7.3L power stroke turbo and a zf 6speed manual transmission.
I'm going to have to remove the auto lever from the steering column, am I going to need a new column though? I'll need to pick up the manual shifter and clutch peddle assembly as well, I'm thinking that I will need the clutch peddle off a new super duty because there hydrolic.
I'm thinking sence there is a new gas tank in the bronco i can just drop that and empty it good to change over to diesel.
Fuel pump, get one off a diesel?
Radiator, the bronco has a new 4 core radiator in it which i think will be enough for the PS.
I'm going to be making my own motor mounts for it so I'm not to afraid of the engine not mounting right, or the transmission mounting right. Is this going to fit? Should I just stick with the c6? Can I fabricate something to get the c6 to mount correctly? Any input would be helpful
/emoticons/[email protected] 2x" width="20" height="20" /> Thanks
