6" lift kit
muddog
Indianapolis, IN
i finally got my lift kit on my 93 bronco. My problem now is the front end sits about 2 inches higher then the back. i didnt put the add a leafs on yet. does anyone know if that will level it out or do i need to put bigger blocks on the rear. Any advice would help. thanks
Yes, the add-a-leafs (AAL) will give 1-2" of lift on the rear axle. That would be better than a taller block, too.
highriderW13
texas
springs r much more prefered than blocks try to keep the blocks at 4 inches or so no to much bigger
