302 motor
papasmurfcdp67
Arkansas
I just replaced the motor in my 1994 Bronco its a high output 302 I have 600 miles on it and it seems so weak my dad's Bronco with a 351 has so much more power why?I know the difference shouldn't be as much as it is.
yo PAPA,
As Bob advised;
Also, by Ford; Symptom Charts — Chart 6
http://www.thedieselstop.com/faq/9497faq/maint/vra/vra07012.htm
1994 PCED OBDI-A
SECTION 7A: EEC-IV Intermittent Fault Diagnosis
EEC-IV MONITOR: Symptom Charts — Chart 6
LACK/LOSS of POWER System Possible Causes Visual/Mechanical EEC Air/Vacuum
  • Check vacuum lines for leaks or wear.
  • Check air intake system.
  • TP sensor
  • MAP/BARO sensor
  • MAF sensor
  • IAC solenoid
  • IMRC solenoid
Fuel
  • Check for correct fuel pressure.
  • Check fuel lines for contamination or restrictions.
  • Check for clogged fuel filter.
  • Fuel Injection:
    INJ 1, 2 (MFI)
  • INJ 1, 2 .. (SFI)·FPRC solenoid·HO2S(s)
Ignition
  • Check for correct base timing.
  • Check for wear or corrosion in distributor.
  • Inspect ICM for damage.
  • Ignition System:
    PIP circuit
  • SPOUT circuit
  • DPI circuit
  • KS sensor
Other
  • Check EGR valve sticking.
  • Check for PCV valve for correct operation.
  • Check for restricted exhaust.
  • Inspect electrical connections, wires, and harnesses.
  • Check for partially binding brakes.
  • Check camshaft timing and cylinder compression.
  • EGR Systems:
    EGRT, EVP, DPFE or PFE sensor
  • EGR solenoid(s)
[*]AIRB solenoid
[*]AIRD solenoid
[*]EPC solenoid
[*]TCC solenoid
http://broncozone.com/topic/14269-code-reader/?&pid=74587&mode=threaded
KOEO
KOER
Coastersfwb
