1995 Bronco Transmission hard shift
carlos cater
i have a 1995 bronco i started having problem with transmission it would not changed.i also lost the speedometer and odometer.i had the transmission fix but my speedometer/odometer doesnt work ,the overdrive light is on the moment it shifts real hard,and the rpm can go as high as 3000.i have this truck since new and the highest it went was 1800 at 70 mph.now it goes to 2000 at 45 mph. iam really dont know if the transmission problem or electrical.anybody had this problem? carlos
Yo Carlos,
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Helps to have someone else assist in this test.
Some basics;
Do KOEO test First
KOEO
KOER
Without a code to narrow down the troubleshhoting, this problem could be caused by a # of things;
bad vehicle speed sensor (VSS) (also called ABS,, DSS sensor) on the 8.8 (rear differential)/ or Connector/corroded wires inside connector;
or cruddy/damaged tone ring in the 8.8;
bad 4WABS Module - It is located below ws wiper fluid/coolant recovery tank. So, the connector can be corroded by leaking fluid;
bad PSOM (Speedo);
bad wiring/shorts /connectors from VSS at firewall, at 4WABS Module and /or at PSOM and then onto the PCM.
If neither a voltmeter nor frequency counter is available, vehicle speed control may be used as a good indicator. If it works normally, then the speedometer module is at least receiving a speed input signal and the wiring and sensor & tone ring can be assumed to be good.
Val
