1986 XLT Power Windows
There you go, Steve has done all the hard work of taking voltage readings.  It's not complete, but shows what you should get based on the position of the switches.  If you don't get those readings then one or more of the control wires are probably broken.
 Thanks Al.
Yo Fred,
Steve'S test shows connector 600F. Any idea of where it is?
His diagram is fuzzy to me.
Yo Fred,
My diagram is for an 80 - 86, Steve's appears to be for a 90's Bronco.  They are essentially the same but connector designations may be different.  It is difficult to read labels on Steve's diagram.  The readings on the motor leads should be approximately battery level.  I'm adding this diagram for some explanation.
K
Kauffmanbros
Awesome! found a few things and it's solved. Both motors were ceased and the driver side switch was bad for the red wire. Instead of trying all the different voltage readings I went caveman and just used a test light. Now I'm trying to hunt down a dual drivers window switch for under $45. I really appreciate everyone's help on this.
K
Kauffmanbros
Hey guys! Thanks for all the help. It ended up being 3 things. 1st was my own dumb fault. I was doing some testing with the drivers side dual switch out of position so it wasn't able to complete the gound (dumb). 2) both driver and passenger motor ceased. 3) driver side dual switch faulty. So now I'm looking for a good switch under $45 that the local yard wants. I really appreciate all the help everyone gave on this!
Yo K,
Congratulations!
You saved $$$ by diy.
Our sponsor, Jeff has the driver master switch for $75.00 new E0SZ-14529-B
http://shop.broncograveyard.com/1981-1986-Ford-Bronco-and-F-Series-Truck-Driver-window-button/productinfo/34410/
Google E0SZ-14529-B
Amazon is $73
E bay 56.
http://www.ebay.com/itm/New-GENUINE-FORD-E0SZ-14529-B-SWITCH-ASY-/201317841466
Etc.
Search for more..
Confirm Ford part number and pic.
http://www.hollanderparts.com/
A yard that uses Hollander Interchange can search other yards and have it shipped
or
http://www.copartfinder.com/finder/searchMake.do
Has Vehicle Pics! They show about 4 - 5 pics per vehicle incl. interior/dash, back seat, front & rear and engine bay.
http://www.car-parts.com/
http://www.picknpull.com
This is a Company name w/yard locations in various states
http://row52.com/Search
Has Vehicle Pics
Also for obsolete parts by Ford long version pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
K
Kauffmanbros
I found this guy on ebay http://stores.ebay.com/switchdoctor?rmvSB=true the switch doctor. I've ordered a switch from an 86 aerostar because the layout is the same. The paddles are blue and red instead of silver, but those can easily be changed. I paid $10 and should be getting it snail mail around the beginning of June. I'll let you know how it goes. Again thanks for all the help!
fred tyler
