1986 Bronco 2, 4x4 Eddie B clutch Problem
Obronco2
1986 Ford Bronco 2, 5-speed overdrive manual transmission. The clutch is not releasing enough when I push the pedal in, If I let it set a while with the engines shut off, it will release enough once or twice to shift between gears and then quits. It drives fine when I can get it into gear, no slippage.The master cylinder resivour is full of fluid. Could it be just the release bearing (throw-out bearing) that needs replaced, maybe the ***** cylinder ? I've never replaced one of these hydraulic clutches, is it hard, any special tools required to do thework?
Anybody's help would be greatly appreciated.
I'm a Chiefs fan, always have been, always will be. BUT...Go Giants! No team ever caught cheating in a season should be able to play in a SuperBowl!!!
FORDPLAY
***** cylinder ....its prob bleeding off...get a new one its easyer to do that thin a cluch....no thay are thay same as doing any cluch..
andre
gatineau hill quebec
u have master clutch cyl and ***** cyl
check inside of truck folow clutch rod look master clutch cyl is leaking
that can b replace easy just a lock pin
***** cyl tranny must come out
some time when master worn **** in air and lose pressure
G L
O
Obronco2
u have master clutch cyl and ***** cylcheck inside of truck folow clutch rod look master clutch cyl is leaking
G L
Taking the xtra minutes to reply to my problems is GREATLY APPRECIATED.
May the both of you recieve twice the payback in some form of good.
I have not yet got under the bronco to look at what you talk about but I will when the weather allows (COLD and WET ) and I'll reply back as to what I find, probably with more questions.
Anybody else have any idea's, please add.
Thanks again.
agzmdv
Taking the xtra minutes to reply to my problems is GREATLY APPRECIATED.May the both of you recieve twice the payback in some form of good.
Thanks again.
Will be taking on this project this weekend. Clutch Kit, Master and ***** Cyl, etc.
kyleh01
